Not sure if this is the right sub forum for this question, if not please move.
I have a couple of jobs to get done, first is lining my garage walls with 12mm MDF (I have already fitted the stud frame to the concrete panel walls using 89 x 38mm CLS) and want to nail the MDF sheets rather than have hundreds of screw heads showing.
The second job is that I am building a shed using 25mm x 34mm frame and 150mm x 11mm feather boards to create shiplap sides. The floor and roof will be 18mm OSB (roof then felted).
The floor frame and the wall frames I am happy to screw together but for the shiplap, again I want to nail the boards in place.
At the moment, I have an 18g air nailer and an air pinner. Clearly the air pinner is of no use for this application and the 18g is probably also not up to the task of securing everything with enough force.
So I am looking at another air nailer (as I already have the compressor and airlines) and my question is; is a 16g first fix nailer any good or am I better looking at a framing nailer firing 2.2mm nails? Air framing nailers aren't too expensive but they all seem to have reviews that they are heavy as feck. I don't want to go to the expense of a £500 Paslode when I only have these two jobs for it.
Advice appreciated.
Advice appreciated.
