no, Those screws drill their own hole and leave a very clean countersink. I drove mine flush with the board and they coloured with the Cuprinol no problem.
remember 1 fixing per board per rail in the thick end covering the thin end about a 5mm gap to the board for expansion
or to explain overlap say 25mm then fixing a further 5mm away as 30mm
