Nardi FE?614 oven door removal/return
17 Jun 2014
hi All. Removed oven door for handle & glass repair; now unable to re-seat hinges & door.
Anyone familiar with Nardi FE? 614 hinge as shown in photos?.
Any advice greatfully received :confused: Thank you :D
ps don't have full model number as peeled off
Many oven door hinges are similar. It's usually just a case of feeding the hinge into the slot in the housing until it 'catches'. You can usually feel when the bottom notch on the hinge has hit the correct spot. The door might need to be held in a half-closed position to get the alignment correct. Can be a bit of trial and error.
