- Joined
- 20 Sep 2024
- Messages
- 3
- Reaction score
- 0
- Country
TLDR: Building brick structure, only have 50-60cm clearance around three sides; can't fit standard trestles. What do?
I'm currently planning a brick-and-block garden gym at the bottom of my garden. It'll be 4.5m x 3.5m x either 2.5m or 2.8m depending on planning permission. Everything's going swimmingly (except the COST), but for one snag : The area is bounded on both sides and the rear by neighbouring fences, and I can't find trestles that will fit. I'll have 50cm clearance, and maybe another 10cm if I remove the fences (there are sheds on the other side of the fences). Standard builder's trestles are about 1m wide at the base. As I see it, my options are :
a) Change the design. Absolute last resort - it'll be cramped enough as it is.
b) Plasterer's trestles. They have a footprint of about 60cm, but they only have a rise of about 60cm. I'll need at least 1.3m to have a chance at laying decent bricks.
c) Using something, anything, else to support the platforms. Fall risk is not a massive concern here - there are fences, fenceposts and sheds I can brace against. Still, gravity is a fickle mistress and I'd do well to flatter her.
d) Build both leaves from inside. I'm not nearly skilled enough to do a good job - even if the wall will be hidden behind a fence.
Does anyone have any suggestions?
Thanks!
-ph
Thanks!
-ph
