Hi everybody
My part-one, part-two storey extension has commenced, and I have hit my first stumbling block.
I managed to get walls of 260 mm thickness, however, I cannot get my structural engineer to design columns that will fit in this thickness (100 mm internal blocks, 25mm insulation, 35 mm air, 100 mm brick).
I have to have a box structure to support the top beam which is a 203 x 203 x 60 (and ground beam 203 x 203 x 46). The top beam will support 17.5 Kn/m dead load, and 7.0 Kn/m live load.
The builder has knocked down the columns from 203 x 203 x 46 to 152 x 152 x 30, which shows that he completely overengineered it in ths first place, however, even these smaller columns will protrude into the room.
My builder has proposed three box columns x100 welded together however the engineer has said that this is not possible.
How do others manage to lose these columns into the walls.
