need a 2 gang blankplate/built in terminal block ?
11 Oct 2010
Leeds
i need a 2 gang blankplate with terminal block incorperated ? if anywhere stocks such an item..lets say similar to a 25amp flex outlet plate,reason is to blank off a 2 gang socket which is in the stupid postion of above a cooker..probably from yrs ago b4 someone changed the kitchen plan around! :eek: it is currently a flush 2 gang socket and this landlord wants to have it done this way rather than connector blocks/blankplate...anyone know where stocks anything like this or any other ideas cheers :)
Has he explained why?
When you tell him that such an accessory does not exist, how does he react?
If you suggest that you'll fit one if he supplies it, what do you think he will do?
Neither assertion is true.
But clearly I do have something in my head, unlike you, the idiot who thinks that what I wrote was ranting.
Not much point buying something then whose only difference from a 2-gang pattress box is the chock-block inside....
[EDIT]Edited to correct dreadful grammar.[/EDIT]
