I want to plaster over a cable and found the capping method a pain before so I am leaning to the oval conduit.
The cable is a single 2.5mm twin and earth from a socket to an fused socket what sized conduit should I use i take it de-rating wont be too much of a factor as the fuse in limited to 13amp
Also as this conduit runs past the main gas entry into the house can I also run a 10mm earth in the conduit to get the mains bonding installed assuming the conduit is big enough?
