- Joined
- 12 Aug 2015
- Messages
- 2
- Reaction score
- 0
- Country
Property Type: 90's, Detached, Cavity wall
Hi all,
I'm looking advice on my leaking parapet walls. There was penetrating damp coming in to the bedroom on one side of the house (the same side as the pictures). After drilling a hole and taking a sample of the mineral wool insulation, it was completely saturated and has since been removed all over the house. Now when it rains heavy I can literally hear the water dripping down into the cavity. The blocks on the inner leaf in the roof space are also absorbing water. I thought that this initially due to bridging of the cavity, but seems that water is still getting to them when it rains.
The copings originally had silicone between them which was almost non existent and has since been pointed. I Don't think there is a DPC under the copings but there is some lead tray which doesn't cover the entire cavity? Also the drip seems to be too close to the house on the outside and is filled. (see pics)
I have had a few roofers out to investigate. One suggested capping over the copings with something like Aluminium Caps and the other suggested redoing the lead work underneath the copings.
Need advice on the best way to address this. Is capping these a viable option? As it has been quoted cheaper to do.
I see plenty of similar threads of parapet issues on this but most seem to be either flat wall, semi or solid walls.
Adam
View media item 96885View media item 96884View media item 96883View media item 96882View media item 96881View media item 96880View media item 96879View media item 96878View media item 96877
Hi all,
Adam
