Hi, I've got a double wall socket it's mounted on the skirting board not inside it (if you know what I mean), and the problem is it's mounted to low, we had new carpet fitted and it's made it even worse we can't plug anything in it, I want to move the socket on top of the skirting board, but how will I extend the wires about 10 inches higher?? will it be as simple as using those long plastic wire connectors (forgot what there called) or will it be harder then that?
