Hello,
Here's some background on our setup - 2 bed split-level flat with indirect system upstairs, boiler downstairs. The motorised valve is stuck open so the CH comes on whenever HW is switched on. Motorised valve is 3 port (mid position) British Gas with the blue plastic cover (think it's Drayton) with quick release removal... The valve was fitted before we moved in, but sticker underneath says warranty expires in 2002. Valve 'looks' good, it's the shiniest thing in the system. Sine we moved in in May, HW was fine and radiators never came on, but recently the Mrs switched on the CH using the 1 hour boost, and since then the CH always comes on with the HW, and switching the CH on by itself has no effect.
I removed the actuator to see if the valve itself was frozen, and I can quite easily turn the valve from center to the HW position, but it doesn't like going the other way to the CH position. I was wondering how much these were supposed to move.
If possible I'd love to be able to swap out the actuator only. If I have to replace the whole valve I will, but I don't really want to drain down. I have replaced the gate valves and stopcocks on the system, so pretty handy at this but still a novice.
I have uploaded a photo of the valve with the actuator off. I can turn it from this position anticlockwise which is HW. It doesn't go clockwise past this position.
Any info would be helpful so I can crack this!
Thank you,
Stuart
Thank you,
Stuart
