Need Help - Block render / coating advice??? With Picture.
Status
Not open for further replies.
9 Dec 2004
Hi all
I'm having a right big problem here. I need to cover some normal concrete blocks in a render or coating of some sort to match fairly closely with the blocks on the below picture. I blocked up an old external doorway you see.
Yes, they are not very attractive, I know - but its a nice house inside and a great location...
Anyway, No one does these blocks anymore so I have to make up some myself (I've searched everywhere on line and out at the builders yards).
Its a sort of grit stone contoured facing. Any suggestions? I imagine I could put a render on the blocks and put the contouring in when its still wet..but would it hold for years to come?
Please help!!
Are you sure? I can get some that look similar but are a totally different size. Much smaller than the ones I need which are huge heavy concrete block things.
I'm in Wiltshire - Staffs might be too far. Do you know the supplier(s)? I dont know why they dont do them down here anymore, but I have tried loads of places.
Thanks for that - Sadly the blocks are much shorter than mine so are no good. I'll keep looking but dont hold out much hope - so might try to do my own on a test block or two.
Status
