I need to fit this ceiling bracket to my upstairs ceiling. The bolts I got with it look the same as these, they are 65mm long and round about 8mm wide. There are no nuts with these bolts and I'm pretty sure just screwing the bolts into the beams with no nuts on will not be strong enough? I don't even know if 65mm will be long enough to get through the other end of the beam?
Also I need help with working out where to put the bracket, I dont know how to work out where the beam is unless I go into the attic, then how do I work out where I am in relation to where the bracket goes on the ceiling, I could find out where the beams are but it would be a guess as to where the bracket is going to be when I drill through.
I'm not sure this is in the right catagory, if not please move but don't delete
