Our shower tap doesn't stop the water, it keeps on turning.
We gently have to keep turning to the right until the water stops.
See below for a picture of the taps:
I took off the cover of the faulty tap - I can see a screw underneath, I guess this is where I need to start?
Someone told me the thread of cartridge inside has worn out.
They said I need one of these:
https://www.screwfix.com/p/flomasta-ceramic-tap-glands-24mm-x-2-pack/2961F
The problem is that there 3 different sizes on Screwfix: 9mm spline, 8mm spline and 10.5mm spline.
Is there anyway of knowing what size is needed without opening up?
Before opening tap: I've been told I need to shut off the water. The only way I can do this is outside on the pavement. (I saw the builders do this when we had our extension done a few years ago.)
Do I HAVE to stop the water?
I guess if I have to, then I have to.
EDIT: I was told I should replace both cartridges inside. The only thing is that the right hand side is for the water - this is the faulty one. The one on the left is for the temperature. Should I still replace both? The age of the unit is 10+ years old.
Thanks.
Thanks.
