I have just bought a bungalow. Its a very simple long rectangular shape with traditional cut roof and gable at either end.
We are considering changing the internal layout to move the living and kitchen space to the rear with bedrooms going to the front. In the long term they will move upstairs when we convert the loft.
So i have included a crap sketch to help explain.
[/img] View media item 49658
The rear of the house is split into 2 rooms which have a solid dividing wall. I would like to remove this wall but it carries the weight of a haphazardly converted room above and also the ceiling joists for both rooms bear on it.
The floor of the room above needs strengthened anyway so to save having to put a steel in I am considering dropping the ceiling height 8'' and putting new joists in spanning right across to both outside walls (standard cavity walls)
This would also give me an extra few inches in the room above. Obviously though i don;t want to have a very low ceiling so a big 300mm deep JJI joist may not work. The span is 5.9m will any standard timber joist make that?
Also other ideas (such as hanging them off the purlins which run perpendicular to them) welcome. We will be getting an architect to do some drawings at some stage.
Sorry its so long. cheers
