- Joined
- 13 Dec 2022
- Messages
- 59
- Reaction score
- 1
- Country
So I'm about to order a routed chipboard structural flooring from Omnie (22mm) which will replace my current floor boards. The joists on this suspended timber floor (downstairs) are 100mm deep and so I've purchased some PIR insulation and was planning on taping all joins and over the joists so it creates a continuous vapour layer. Including against the walls. My dilemna is that chipboard flooring is usually glued down, and I'm now worried that if I span 100mm foil tape over the joists joining the two PIR boards either side it won't leave a suitable surface i.e. wood for the glue to adhere to. I was going to glue the tongue and grooves and also every joist and noggin supporting the floor, then screw it down.
Which of the following should I do
1.) Tape it all with foil tape as planned and simply glue the boarding down to that
2.) Tape only the joins where PIR meets PIR but not against or over the joists leaving a glue area but slight air tightness issue
3.) Something else?
I'd love to get a comfortable answer for this before I place an order for the UFH chipboard flooring today. I've already got the PIR and tape arriving on Friday
3.) Something else?
