Hi
I am re modelling my kitchen and want to try and get my sockets and appliances wired up so there is minimal plugs so i was think of this below. If you could read this and tell me if i could get this done.
I have a double socket from a ring mane and a 20A DP Sw + Neon for my water tank on one wall. One this wall i was going to have a switched 13amp FCU spur installed and have my fridge freezer hard wired to it. Is This Ok
Next wall i have a double socket. I would like to have a 13A Sw FCU + Neon spur coming from the double socket. I would then like my outside light connected to the Switched FCU. Is This Ok
Next Wall. I have a double socket and a cooket switch and socket. I would like to run a double socket spur from the Ring mane Double socket. Is This Ok
Next wall i have a double socket Spur from the opposite wall. I would like to run a 13A Sw FCU + Neon spur coming from the double socket spur then a Double socket spur from that for my under cabinet lights
Or could i have the double socket spur changed to a 13A Sw FCU + Neon spur then run a double socket from that for the cabinet lights as i will need to for the above lights and below lights.
Can you please let me know if i could get this done and if it would be a big job for someone, also how costly. I could have the boxes fitted and ready to just wire up if this is ok.
Bob.t[/b]
Bob.t[/b]
