got a couple of strange issues going on and wanted some advice.
firstly there are no errors codes and the boiler does seem to be operating in that I'm getting HW and CH but i have noticed that it seems to be in a cycle where it will begin heating then cooling then heating back up. so basically it fires up and heats to the temperature ive set for example 53 degrees then it seems to start cycling with the pump running and starts cooling till it gets to around 42 degrees then it fires up again till it gets to 53. is this expected behaviour because it seems pretty inefficient to heat then cool by 10 degrees only to heat back up instead of just maintaining a constant temperature? another issue which ive had which may or may not be related is that if the power has been turned off and on then the boiler seems to go into an overrun condition with the pump constantly running for hours even whilst there is no demand for heat and all heating channels are off. the last time this happened the only way i could get it to stop was to keep the reset button pressed but even then it would stop and then after about 15- 20 seconds the pump would start running again this happened a few times until i just powered it off on using the power button and then it stopped and settled down again. any help or ideas on this would be greatly appreciated
thanks in advance
thanks in advance
