Hi all, I have quite a few questions regarding wired vs wireless thermostats, and how a wireless one would actually work with an existing system.
I currently have an old wired analogue thermostat in my hall, which opens directly into my long kitchen, with no door between the 2 rooms.
I've read conflicting opinions on locations for having a thermostat wired; some suggest to have it in the room that needs to be warmest (for example in my case it would be the living room or bedroom), and others say to have it somewhere cold and that the hall is ideal.
1) What is the consensus on this? Is there a proper, professional absolute recommendation?
I've also read that you can't have a thermostat in the same room as a rad with a TRV.
2) How is this supposed to work? Especially with a wireless stat that you can take anywhere you need the heat?
3) I thought every room apart from the bathroom is best to have a TRV installed?
4) If the stat must be in a room with a TRV, is it best to have the TRV set to its highest setting to get the proper use out of the stat?
5) Would the wireless stat try and bring every room up to the temperature I’ve set for one room, unless I've set other room's TRVs accordingly?
I can't find anywhere a decent article or list of wireless vs wired thermostats; or for that matter, Nest vs. wireless.
6) I know Nest is supposed to be "smart", but isn't a wireless stat's main advantage that you can have it in any room? Wouldn't this make it better than a fixed stat in any case?
7) What are the biggest downsides to a wireless system?
Thanks!
Thanks!
