I have laminate flooring on the entire ground floor (living room, hallway, understairs cupboard, dining area and kitchen).
I need to lift the flooring in the living room and hallway so that the plumbers and electricians can get to the floorboards.
However, I want to preserve the flooring in the dining and kitchen area. So, I need to cut the flooring neatly at the point where the living room becomes the dining area and kitchen (it's all open-plan).
The cut needs to be a neat, straight line around 10' in length.
What is the best tool to use, ensuring I don't cut into the floorboards or any wires that may be lurking immediately underneath the laminate flooring?
I presume after that lifting it all up is fairly straightforward?
