I need to extend / re run some cables to my veritas r8.
The first cable is to a magnetic door sensor.
The second one is a single cable from the control panel to a small junction box. Into this junction box is another magnetic door sensor and the keypad.
I've downloaded the inst manual and done some digging but can only find info on altering the keypad wiring, from what I can gather would be -
Panel cover off
Disable tamper
Power off
F4 fuse out
Alter cable
Power / panel back on.
If this is right then is there anything else I need to do in terms of extending the magnetic sensor cables? Are there any other fuses that need to be removed or are they run from f4 as well?
I was thinking of disconnecting the battery as well, but I understand the bell box has its own battery and the interruption in power will cause it to sound? (I don't have any long ladders to get to the bell box).
It will probably take a while to route the cables so I don't fancy the sounder going off the whole time.
Can anyone go through best sequence for doing this please?
Cheers!
Panel cover off
Disable tamper
Power off
F4 fuse out
Alter cable
Cheers!
