I've just moved into a flat and the previous tenants appear to have gone to town with their wall hangings. There are lots of holes drilled into the walls with plastic studs inserted. (a) Do I need to remove these studs before filling, and if so how do I remove these studs and (b) what do I use to fill up the hole, i.e. what type of filler and tools (such as scraper... or other suck like)??
As you can tell, I am not a regular DIYer, so any advice is much appreciated.
Also, they seem to have gone to town with a ceiling in one of the bedrooms. I think they had some sort of hanging item where they drilled a hole in the ceiling to hang it up. Like a model plane for example. I do not know what used to be there, cos they've taken it away, but left the hole there. What do I use to fill this hole up with. It's not huge - slightly bigger than a regular drill hole, but while I am at it, I thought I'd fill that up too.
Thanks in advance to those that respond.
