Need to identify plastic pipe
19 May 2007
Part of my central heating uses Hepworth plastic pipes. It says Hepworth 15 x 2.0 on the pipe. I need to T off the pipe and need to know whether only the same brand fittings will be needed or are plastic pipe fittings generic ie will any make of fitting be ok?
Other types may fit, but keep your pipe guarantee safe and fit Hep2o fittings. Remember to fit inserts as well...
You can also use compression fittings,indeed some prefer this method,again always use inserts.
