Need to largen standard overflow hole in a Carronite bath
31 May 2010
Buckinghamshire
I am fitting a new Carronite Swallow 1800 bath ...
(http://www.carronbathrooms.com/Carron%20Bathrooms%20-%201800x700.html)
...with a Hansgrohe Exafill S filler/overflow ...
(http://www.hansgrohe.co.uk/uk_en/110381_32313533305F32355F3632313539.htm) ...
so have a overflow and waste holes ONLY
The problem is that the overflow hole is too small for the Exafill filler/overflow component and I need to drill it out - but I am concerned for two reasons ...
1. if I cut the Carronite with a regular hole saw, do I risk splitting the bath?
2. given there is a hole there already, how can I stop myslef slipping?
HELP PLEASE!!!!!!
get a pice of ply 6 or 7 inches wide. cut a hole in the same size that you need so forming a template. clamp it in place with a couple of squeezy clamps and use this to run your holesaw through.
Just come inside and seen your response - many thanks ...
I did it the other way ...
Clamped a piece of ply to the outside - with the centre of the old hole marked/lined up - masked the whole area - used the mark for the holesaw arbor - job done ...
And Exafill S fitted ...
