Hi.
I bought a house and when I ripped up kitchen floor, the kitchen floor is approx 20mm lower than my hall floor which has floorboards and wooden floor laid onto it.
The flooring company will not run the laminate right through to the kitchen because 1) the drop is too far and 2) there is some un-eveness on the floor where the extension has been built. It was built a few years ago. So the kitchen floor is uneven is areas as well.
I have been advised different options.
1) use self leveller to bring it up 12mm or so, then use plywood to bring it up 6mm, then lay the laminate on top of this.
2) use self leveller to bring it up 18mm.
3) use concrete and a screed finish
4) asphalt (do not want to do this because of the smell, mess and so on).
Do you have any advice on what would be best/suitable? My kitchen would be used by a family of 4, so lots of usage.
1 other issue is my kitchen worktops, if I concrete it or self leveller it, my worktop legs will need removing and something in place whilst it sets? Or do I just fix it all in and when I want a new kitchen just rip everything out?
