Need to move a double plug socket. Advice please.
16 Mar 2013
Kent
I need to move a double plug socket about 1.5m along the wall. The problem I have is there is not enough slack. I have pulled the floor boards up and there are two wires going to the socket. The wires colours are 2x red 2x black and 2 y/g ( in one sheathing ).
Can I pull both cables back and extend them using a junction box?
Any advice would be great
Cheers
Can you get to where the two cables come from? If so replace from that point to the new location. Sorry but the rules state that junction boxes have to be accessible for inspection.
Thanks for the reply. They seem to be going off in separate directions. I can trace one but not the other.
Was hoping there might be a simple fix for it. Don't really want to be pulling all the floor boards up in every room. :(
If you use a Maintenance free junction box then you can just joint them both , or if one goes the right direction just joint one and pull the other one back to the new socket position.
if you are jointing them then do not be tempted to just run one cable to your new socket position and join all three cables together in the JB. This makes it very hard for anyone to trace a fault if one should happen in the future.
Nick
Excellent, I should only need to joint one cable as the other will reach.
Many thanks Nick.
Next problem will be finding a maintence free junction box, might have to go to a decent electrical wholesalers as i have not seen any in the DIY sheds .
Nick
Makes sense. I'll put that on. Yes will be using the new colour coded cable for the extension.
Many thanks Nick. Can get the wife off my back now.
