I wonder if anybody can help!!
I have a Potterton Suprima 50 (yes I know they're rubbish!!). I'm biulding an extention and the flue is directly in the way of the new brick work. I haven't enough room to go up but I have thought of a way that might work and I wonder if anyone could give me an opinion on whether it would work.
According to the manual you can have a total flue length of 3.4 meters with 1 meter equalling a 90 degree turn and 0.5 = 135 degree turn.
I've worked out if I turn the connector going out of the boiler 90 degrees I could then have a 20 cm straight followed by a 90 degree turn angled at 45 degrees up then have another straight length of 60 cm followed by a 135 degree turn followed by a vertical flue kit which would be high enough to clear my new extention roof by the required 30 cm. This comes to the maximum 3.4 meters.
I hope that makes sense!!
Will it work???
Any advice greatfully recieved - the alternative is to pay £1500.00 for a new condensing boiler located in a different part of the house which as well as the expense will make a huge mess!!
Help!
Will it work???
Help!
