We have received planning permission for an extension and I need to get the meters moved.
The electricity is on the left side of the property but will need to be mounted on a temporary board at the boundary line on the same side during works. It will then need to be moved to the outside wall on the same side afterwards.
The gas meter is attached to the outside on part of the property which is being demolished. I suspect that the gas pipe runs under where we will be excavating and building the garage. Ideally, it needs to be capped off in the road and then subsequently relocated to a similar area it is now (but on a new outside wall).
The builder says he can install 4" service ducting for new gas services, but any idea who I need to contact to get a quote for such works and are there any tips on how to play what I imagine to be an expensive game?
Regards
Peter
Regards
Peter
