I think I may need to replace my pump?
I have a back boiler and upstairs is the pump and I get get hot water : on the water only setting however I am unable to get any heat out of my radiators when I flick the switch.
The rads have all been bleed and are squeezing out cold clear water . just not getting out
How I can check to see if my pump is working ? it has a tap valve above the pump and it appears to be a 10p screw twist opening
Is sounds as water is running through the pump but the impellar is not working
Please any suggestions ? or shall I replace it ? if so how ? simply unthread the pump ???
many thanks
teresarob
many thanks
teresarob
