Hi
Can anyone help please? I need some advice please on replacing my wired room thermostat. I’ve had a Worcester 27cdi boiler fitted in my loft recently and an old style dial wired room thermostat on the floor below. The problem is that the lowest temperature setting on the dial is 10 degrees. I’d like to be able to turn off the central heating with a zero setting on the room thermostat or as low as possible without having to go into the loft.
I’m keen to have a wired room thermostat and not wireless or radio frequency. Is there a wired room thermostat with a zero rating or one with lower than 10 degrees and / or is it possible to get a wired room thermostat that includes a programmer (not wireless) that I could use? There’s already a programmer in the loft by the boiler (just hard to access) so it’s not essential but would be convenient. I just don’t like heating coming on in the winter when the boilers on and I’m out or sleeping and I don’t keep regular working hours each day so need flexibility.
Please let me know if any model you suggest is two wired or 3 wired as it may affect the mains cable already fitted and I need to get something compatible with that and the new boiler.
Thank you
Thank you
