Hi all,
My Neff b45e52 Oven just went bang. I switched it on, the light briefly flashed on and then t went pop and tripped the breaker.
After turning the breaker back on, I turned the oven back on and although I have power (the clock is on), it doesnt do anything else.
I removed the bulb and it just fell away from the metal screw (which I had to remove separately with a pair of pliers).
The last bulp I changed did the same so this might have just been a coincidence.
The oven is only about 3 years old.
Is there anything I can do/check myself or is this an engineer job?
I have also looked for the serial number which the instruction manual says is on the "right hand side of the oven door" but I cannot find it. Can anyone advise where I might find?
Thanks in advance
Thanks in advance
