NEFF dishwasher drain pump run continuosly
3 Aug 2014
Durham
HI,
I've got a NEFF dishwasher that runs drain pump continuously. I've checked the base, there is no water in the bottom, the water float isn't stick either. When i lift the red arm, the switch clicks on and off, so everything looks perfect. What else can i check?
Hi Orit, did you resolve this problem as my Neff is doing exactly the same! Thanks
