- Joined
- 16 Apr 2020
- Messages
- 3
- Reaction score
- 0
- Country
Model S511A50X1G/51
I will start by saying that the dishes have had white residue on them for about a month before the actual fault appeared, like they hadn't been rinsed. Also and I do not if it was coincidence, but the machine was running and my RCD tripped and after that the following fault manifested itself. So I do not whether it was cause or effect.
Fault:
The machine starts, fills and drains on all cycles, it just stops near the end on the flashing tap symbol with bleeping. I have removed the water inlet filters and cleaned, I have removed the pump cover and checked for obstructions and that impeller rotates freely, I checked the drain pipe, I have measured the inlet water flow to be way more than required, I have left it switched off for a day at mains, I have ran on every cycle and the fault is consistent with the tap flash towards the end of the cycle. Machine is a few weeks out of warranty. Can anyone help?
Fault:
