Evening folks,
I think i know the answer to this question but thought I'd check with those more knowledgeable. I've donated my old double oven to a friend, the oven's rated at 5.1kw and worked perfectly. With it fitted at my friends it trips the mcb. The oven feed in their house is 10mm cable to the oven connection point then 10mm to the oven the the mcb in their consumer unit is rated 6a fitted on the non rcd side. I think the oven is supposed to be on a bigger mcb such as a 32a or maybe a 40a and as such the oven is tripping the mcb that's too small, would this be correct?
Chris
Chris
