Hi All,
We inherited a NEFF double oven when we bought our new house. The glass viewing panel (the inner panel of what's effectively a double glazed door) was becoming detached and finally it's become so detached that I decided to see if it could be repaired. It appears the glass panel on the inside is attached to the metal frame of the door using dark brown silicone sealant - that's all. But the silicon was caked in the oily cooking residue of ages. I have cleaned it pretty much as much as I can, but of course the sealant has no desired to adhere to the cleaned glass panel. Ideally I'd like to replace the sealant, having thoroughly degreased the door frame and the glass, but I suspect the sealant may not bog standard silicone sealant from Unibond. Can you advise me what the correct sealant is, where I would get it, and how long it might be expected to require to cure? I presume that the sealant needs to withstand tempertures of ~200*C. If the sealant is not easily available, would it be possible to use an alternative bonding agent on top of the degreased old sealant. I'm a great fan of Araldite. Would that adhere, and withstand 200*C?
Thanks for your help and advice,
Dornfield
Dornfield
