Neff Induction Hob.
15 Jan 2017
I have a Neff induction hob probably 8 years old. It was working great, then went away for a couple of days. When i tried to use it on my return it was dead. It had tripped back to the fuse box. Having sorted that, the left side now is only working although power is getting to all the hob, the two right hand side elements will not work, although there is power to the controls.
Any suggestions?
I had this problem opened up unit and two PCB boards - one for each hob half. Problem was loose was large capacitor with failed solder joints. Resoldered and problem solved.
