Sod's law it's just out of guarantee and it's come up with this error code. I've googled it and I can't find what the code means. Can anyone help please?
However, the insides of microwaves aren't a place you should be messing around in, if you don't know what you're doing.
The high voltage capacitors in a microwave can kill, even if the microwave is unplugged.
Proceed with caution!
Found this thread via google, so to help anyone else who comes across this, in my case it was the magnetron that needed replacing, part number 12006667.
As per RandomGrinch - the insides of microwaves are not places to be messing around with, so do as I did and get it repaired via Bosch/Neff directly.
New magnetron and all working perfectly. No other parts swapped or work done. My model is C17UR02N0B/02. Symptoms are E1006 error code and only runs for 10 seconds then stops, sometimes displaying the error, sometimes not.
