Neff oven does not heat up
26 Dec 2006
Carmarthenshire
:( I own a NEFF built in single fan oven. The grill works, the fan works but it does not heat up. Was unable to cook my Christmas dinner can anyone help with a diagnosis. Thanks
You may have sorted your cooker now, but just in case you haven't. I had exactly the same problem with my Kenwood fan oven.
It turned out to be the heating element, whic cost me £34. It was fairly easy to change. If you have not fixed your cooker yet it may be worth checking out the element. If you have a multimeter you can check if it as gone open circuit or short circuit by checking the resistance across the two connections.
Hope this helps. Let me know if you need more info.
