So just done my annual oven clean on a NEFF U12M42N0GB, this time I decided to remove the plate that covers the fan and element at the back too. I noted there were only 3 screws (instead of 4) and one was fairly lose, but didn’t think anything of it.
Anyway, went to put the plate back on and only 1 screw got any purchase. In the back of the oven (not the plate), the others look like the the metal round the hole has corroded (the paint/enamel round the holes had come away around 5-10mm from the holes), and one hole was far larger than the screw.
The plate is just about staying in place, but anyone recommend a way of getting it to stay on with screws?! ( possibly just replace with wider screws is the only thought, not sure if I will need to drill the plate and if that will have a negative effect on the plate.
