- Joined
- 16 Oct 2015
- Messages
- 2
- Reaction score
- 0
- Country
I have a Neff U1422N0GB/02 oven and have a problem with the bottom element (I think). A bit of background to the problem......
Last weekend my wife decided it would be a good idea to use the Aquacleanse function, where you put some water on the bottom of the main oven and then use the function to clean. Since then, whenever we were turning the dial for the main oven past the light function (so on to 50 degrees), it would trip the RCD. The top oven and grill work fine and no tripping was experienced there.
I called Neff and they suggested doing a reset, so holding the clock button for around 10 seconds on switching on the oven, but this had no effect at all, waste of time. So I did some research and it looks like this is a common problem, and is due to either the fan element or bottom element burning out. I got hold of a multimeter and have tested both of these elements, and they tested OK. I then tried disconnecting the bottom element (after taking the oven out) and everything seems to work OK! Strange that it tested OK for impedance, but it must be causing the problem.
My question is this – is this bottom element needed, other than for the Aquacleanse function? If not, then I’d rather not spend circa £50 and more of my time to replace something that I will never use (I daren’t use this cleaning function ever again!). If I disconnect and isolate the 2 clips that would connect to the element, will this have any effect on the running of the oven? Also, any advice on safely isolating these 2 clips, other than wrapping them thoroughly in insulation tape and making sure they are well separated?
Any help would be most appreciated!
