Negative flow shower pump
14 Feb 2012
Derby
HI
Im installing a new bathroom and I need a little advice on negative flow pumps.
I want to:
• Instal a negative flow pump in my upstairs tank cupboard (cold water header tank is a smilar height to the shower head)
• Only pump the hot water and leave the cold from the mains, its a decent pressure and its going to a thermostatic shower valve panel thingi
My plumber has said I should install a large cold water tank in the loft and install new piping direct to the bathroom and pump both the hot and the cold with a dual positive flow pump.
Im not keen on this as it seems a little old fashioned and a lot of hassel.
All advice gratefully received.
Thanks LEE
Sounds like your plumber knows what he's talking about. Mixer showers need balanced pressures and, if pumped, a large enough cold water store to ensure that the pump doesn't run dry.
HI
I've been thinking about this and really just need to know the best cause of action.
The options I have are
1) Put a large cold water tank (114 litres) in the loft and run a positive head twin impella pump for both hot and cold water to the bathroom.
2) Pump the hot water with a single negative pump and use water at mains pressure.
3) Install a unvented cylinder, but im not sure about the costs and its all a bit confusing as I read something that said these dont work with showers.
Id rip it all out and put a combi in it I hadn't replaced the boiler about 18 months ago.
Thanks again for all your posts and help
LEE
first choice would be the unvented cylinder if your mains pressure and flow are good enough (and budget) second would be replace the tank in loft but I doubt 114 litres would be enough stored water, 225 (50 gallon) would be the minimum I would use with a shower pump, you will have problems if you use a single pump and mains pressure, not a good idea for several reasons.
