Hi all, I'm after some guidance as the council have been less Tha helpful in the past.
I live in a 1930 semi, solid brick. The neighbours bought their house (before we purchased and moved in) as a 4 bed. The garage and utility had been illegally converted with an additional 4x4 hideous extension at the back. The council confirmed there was never planning (it wouldn't pass) of building control consultation. Also chimney breasts removed etc etc.
New neighbours are frankly idiots and have hired the cheapest tradesmen possible to do piece meal additions. This all happened over 4 years ago :'(
The neighbours have added an oratory/conservatory (using turbo breeze block on the outside!) this is the flavour of the works being carried out.
The neighbours have moved in an the noise is really bad. I've found out through a hole in the loft wall they have extended into the loft. Further investigation, the other side neighbours have been told its only storage space with a dedicated stair case. There are three couples and about 6 children in the house, so I think the loft is now bedroom number 5!
I've seen they have loft windows installed on all sides I the roof, and lights on and off during the evenings, implying they are living in it.
Should this have planning? Should the council investigate, and do I have to be named as the informant when the evidence of occupation is clear from the road?
I'm a competent diy'er and can see their builders have been cowboys. I will be moving and don't want these idiots next door to destroy the value of my investment. Any advice will be a great help, Beefy
