Talk with Gas Safe quoting the chapter and verse found in boiler manual under flue installation for your boiler. Do not let them brush the issue under the carpet as what the manual says becomes regulation under Gas Safety ( Installation and Use) RegulationIs it actually causing you a problem?
Not so much passing the buck, if gas safe were not nitified of the installation its nowt to do with them and due to the length of time involved B control will be statute barred from enforcement.Be prepared for local building control and gas safe to pass the buck between each other , it is what they do, just dig your heels in and demand results, your neighbour wil not be a happy bunny though , but you havent done anything wrong so why should you have to suffer
not if as you say the boiler was replaced in the last 2 years,it wont and if it was never notified then gas safe have to ask whyNot so much passing the buck, if gas safe were not nitified of the installation its nowt to do with them and due to the length of time involved B control will be statute barred from enforcement.
Its actually 2 years to get it to court, the new neighbour who wasn't there is in no position to claim when it was done.not if as you say the boiler was replaced in the last 2 years,it wont and if it was never notified then gas safe have to ask why
