Yes friends, its fitting a pollen filter to the new shape Focus......
Inside the car, peel back the passenger side carpet.
Undo the Meccano bracket that holds the fuse box in place (2 nuts), and undo the two dzus clips that hold the front of the fuse box up.
Enjoy the tangle of coloured spaghetti that tumbles down and pray that nowt comes adrift.
Undo 3 x 7mm screws that hold the plastic flap over the filter, (limbo ones back over the door sill to do this) and pull the filter element clear. Turn on the blower fan full and experience the debris that ends up in your eyes as the air ducts empty
Attempt to install the new filter, but it won't go in because the wires are in the way...it helps if you compress it, accordion style.
Put the fuse box assembly back in place and pray everything still works.
As you are on your knees anyway......give thanks.
Worst one of all time!!
John
John
