Nest 3rd Gen & Baxi Combi 105e
25 Nov 2017
Hello,
I’ve just got hold of a 3rd gen Nest. Everything is set to go, I’ve got to the wiring stage and I’m a bit unsure... Can anyone provide some guidance?
I have a Baxi Combi 105e.
I won’t be using the T1 and the T2 on the heat link as it’ll be done over the Wi-Fi. And the OT1 and OT2 obviously are redundant.
I really would appreciate some guidance as i’m not 100% sure. I have done a trawl on the net and YouTube.
I’ve attached a picture of both connections from the relative manual.
Thanks in advance.
Chris.
1&2 from boiler to 2&3 on nest, doesnt matter which way round they go, and live and neutral from the boiler to L&N on the nest
Hi Ianmcd,
Thanks for that. Thought it would be simple, just wasn’t 100%
So can the nest not control the hot water on/off?
Thanks for responding.
Chris.
not on a combi it cant the HW is activated when you open a hot water tap the boiler senses this and heats the water instantaniously
One last question/observation does it matter that the 1 from boiler is carrying a voltage? The manual suggests 230v?
Cheers...
