I'm currently contemplating replacement of my room thermostat with a Nest thermostat, but I have a quick question about installation.
I currently have an Ideal Icos HE12 boiler, with a Drayton 522 timer. The room stat is a Drayton RTS1, and is mounted about 15m from the boiler. There are two zone valves on the boiler - heating and hot water. All wiring was buried by the housebuilder during the original installation, and I don't have the option of easily changing / modifying this wiring.
I've checked the wiring at the thermostat end, and I have 4 wires - live, neutral, call for heat and earth. There are no other wires available within the cable running to this point.
Having checked the installation guide for the Nest thermostat it makes reference to a common wire, which I don't have.
My question is - is this needed? I seem to see conflicting reports elsewhere.
