Morning,
I am about to install a Nest Thermostat (3rd Gen) and after looking at what I currently have, there's a couple of queries.
Issue 1: Current Controller has N L 1 2 3 4 and is wired as follows:
N - 3 Wires: 1 is from the fused switch, 1 goes to the boiler and I have another mystery wire which I think is the thermostat ? (more on that in a moment)
L - 3 Wires: Same as above
1 - Nothing
2 - Nothing
3 - Red wire, controller says this should be Central Heating Out
4 - Red wire, controller says this should be Hot Water Out
On the Nest Heat Link I have N L 1 2 3 4 5 6 OT1 OT2 T1 T2 - What should go where?
Issue 2: Thermostat has 4 wires going to it, a Red Wire into 1, a Red Wire into 3, and the 2 Neutrals into 2
Presume this means they are high voltage and I shouldn't plug straight into the thermostat? If so, my question is - where do these 4 wires run back to? Are the two mystery wires in the controller for this? Where do the other 2 wires go? Can I take these out of the equation and wire into T1 and T2 on the heat link ?
Appreciate any helpful advice.
1 - Nothing
2 - Nothing
