Nest installation
18 Jul 2015
If I have an Ideal Isar HE35 boiler when I install my Nest do I follow the switched live diagram or low voltage (dry contact) diagram?
Thanks!
Sorry, I'm not sure I follow - do you mean follow the low voltage diagram? From the manual I can only really see that there are 2 options and they're called switched live and low voltage.
I'm going to be using two cables that run to the existing thermostat to power the Nest thermostat unit on the wall.
Great so as the diagram calls it - low voltage (dry contact) as I'll have N and L connected for power?
