Folks,
I'm close to working out how to replace my Danfoss CP15 with the Nest Heat Link, but the terminology I'm just not familiar with (layman).
Hopefully 2 images show up in this post.
http://support-assets.nest.com/images/tpzimages/comp-system-wiring-diagram.png
The wiring diagram probably doesn't really matter, all I need to do is rewire the 4 wires in the Danfoss into the Heat Link instead.
- N and L are easy enough.
- 4 on the CP15 refers to "HTG On" (heating on, I guess), so this wire should go to "Call for Heat" on the Nest?
- 3 on the CP15 is "DHW On", but this seems to refer to domestic hot water, whereas the boiler is for central heating only (Greenstar 15Ri). Where should I put this wire in the Nest, if anywhere?
- Do I need to use either Common or Satisfied on the Nest? I think maybe Common should be wired into mains live.
As you can tell, I'm a bit confused, having little idea about boilers or wiring, so any help will be gratefully received!
F.
P.S. I expected the wires into the thermostat to come straight from the boiler, but they come from the wall! Is my wiring just screwed up?
F.
