Hi
I've just replaced 2 light fittings in my house.
Both fittings were connected to a 2 way switching arrangement.
The first fitting (on the landing) has a cable (red, black, earth) coming in (from another light fitting) and another cable (also red, black, earth) going out (to another light fitting). There are also 2 red wires (and earth) coming into the rose (live and switched live). I have this fitting all working, no problem.
Now, the other light fitting (in the lounge) is also 2 way switched. I expected the same wiring arrangement as the landing light and therefore, I didn't make a note of the old connections. As before, it has a cable in and out (from / to other light fittings). However, instead of 2 red wires from the switch, there are 3 wires (red, yellow, blue)(and also earth). The red is live, yellow the switched live and blue is neutral (?). Back at one of the switches controlling this fitting, this blue wire (neutral) is connected to what appears to be neutral using terminal block. In the light fitting, I have commoned this neutral to the other neutrals. This light fitting also works normally.
I was just wondering why the 2 fittings are wired differently. The house is mid 1980s. The lounge switch is directly below the consumer unit. Therefore, is it wired differently because the power to all the downstairs light fittings passes through this switch ? Also is it correct for the this extra neutral to be commoned in the ceiling rose with the other neutrals ?
Thanks in advance.
Thanks in advance.
