thanks in advance for any help.
Heres the situation, going to be sorting out some electrics in a house outside of the uk, standards in the country are pretty much non existant and currently its so bad you get a shock just touching the metal casing of appliances.. probably some kind of neutral to live short.
Dont currently trust the provided neutral for the house from the electric company...the main neutral rod is only sunk a few inches into the ground..not even straight lol so thats how far down its sunk... and thats the central neutral for probably about half a dozen houses, the neutrals arent even bonded togeher with proper electrical cable its done with U clamps and twisted steel lifting type cable... and not even that is quite neutral... was enough to give a shock.
So, plan is after the meter at the fuse board, rather than relying on the provided neutral which doesnt appear to be a very good neutral.. sink a rod into the ground deep enough to provide my own neutral, then at a reasonable distance away sink another rod into the ground for an earth (which currently is non existant)
Any sugestions or advice on best how to go about setting up my own neutral and earth other than sinking rods deep enough into the ground to effectively provide a neutral/earth.
